Ftp hangs at " open port "
I have a small and irregular problem with the new ftp-update program. Sometimes it hangs when opening the port, i.e. : the connection with the ISP is estblished,but the ftp doesn’t recognize this and keeps trying to open the port infinitely . In the end I have no choice but to kill the ftp with ctrl/alt/del , bexxause both abort and fkill/force hangup don’t work either. This doesn’t happen evry time, but ocasionally. I’ve set the wait on slow connection to 12 minutes and the delay is at 10 seconds , because before it tended to hang completely because the ftp wanted to update while he connection wasn’t yet established…any suggestions ??
Rik
is this with a dial up or permanet connection?
there is a problem when a second ftp starts and the first one is still establishing a connection…the second one then does not when the connection is established
i will see what i can do
It’s a dial up connection (56k modem ) . It’s only three things I programmed the ftp for : download 2 metars and upload to both wunderground and aprs …
Rik
i am uploading vers 9.30d/6.24 now…
should be much better
hang in there!
aslo, i see some people do not have ticked show in system tray under connections…
with the new ftp, I get an error messge, when my DUN-connection ist not available, becouse an other PC uses it (I dont have internet sharing).
The old ftp in that case waited one minute and made a redial, the new ftp doesnt, but waits for at about 5 minute and then closes.
Can I chance that?
Peter
And I forgot
With actual version af ftp I have the same problems as rikwes!
Peter
the cascadign open port i am sure i have fixed in the latest verison, as i was affected too…
does it just happen if you are already connected ?
Yes, it is connected, but the only thing ftp does is writing hundreds of times “open port”.
When I cancel it with strg+alt+del, the modem hangs up.
Peter
Add me to the list ( I’m getting the error as well - error 134 ) & the FTP connection stays connected .
:cry:
glad the old FTP still work’s :stuck_out_tongue:
hi all,
i have a permanent (fast) internet connection
so it’s more clear what the status is (vs a modem)
when ftp 's hanging I can see in the logfile
the password wasn’t accepted and ftp tries and tries
I have to fill it in again after update WD
and when dubugging something
but then it’s working for a while or permanent
what does all your log file says ?
maybe this can help some of you :slight_smile:
Not “Open Port” failure. That is next, but, “Error message”.
Win 98SE 56K Dialup
From ftp v. 6.24 log.
Starting to Dial Connection: Amud
Open port
Port opened
Connect device
Device connected
All devices connected
Start authentication
Authenticate
Checking username/passwrd
Authenticate
Authenticated
(…waits about 20 sec. then continues…)
Logon network
Connected
Checking for what else to do…
there are 2 more things to do
Logging onto NOAA FTP server…205.156.51.200
Connecting to FTP server.
Connected.
220-WARNING
220-
220-This is a United States Government (NOAA) computer system, which may be
220-accessed and used only for official Government business by authorized
220-personnel. Unauthorized access or use of this computer system may
220-subject violators to criminal, civil, and/or administrative action.
220-
220 tgftp.nws.noaa.gov FTP server ready.
USER anonymous
331 Guest login ok, send your complete e-mail address as password.
PASSWORD=****
230-Please read the file README.TXT
230- it was last modified on Mon Aug 19 13:36:34 2002 - 91 days ago
230 Guest login ok, access restrictions apply.
changing directory to /data/forecasts/zone/nc/
CWD /data/forecasts/zone/nc/
250 CWD command successful.
Next file ftp down
PWD
257 “/data/forecasts/zone/nc” is current directory.
Retrieving the NOAA file ncz050.txt now
PASV
227 Entering Passive Mode (205,156,51,200,25,31)
RETR ncz050.txt
150 Opening ASCII mode data connection for ncz050.txt (1344 bytes).
226 Transfer complete.
Finished ftp download
QUIT
221-You have transferred 1383 bytes in 1 files.
221-Total traffic for this session was 2309 bytes in 1 transfers.
Disconnected.
221-Thank you for using the FTP service on tgftp.nws.noaa.gov.
there are 1 more things to do
Next file HTTP metar station download
http://weather.noaa.gov/pub/data/observations/metar/decoded/KTNB.TXT
Download complete
Finished downloading metars
Finshed email agenda
Finished email agenda, no ftp items to do…
Will disconnect regardless flag is set…
Disconnecting the modem now
(…Modem does not disconnect, receive “ERROR MESSAGE”
Ftpupd
143: Busy performing current action…)
Overall time out
(…receive “ERROR MESSAGE”
Ftpupd
Overall time out
Ftpupd
(Disconnect modem by unpluging modem from phone line.)
(Exit ftpupd by clicking on X box. or “Abort” button.)
Only fails with dialup. High speed (DSL) works great, only I have Dialup at the weather station location.
that would be caused by it finishing when it has not acutaly finished yet!
just a metar download as the only agenda item seems to be the culprit (if it is done with other agenda items then i think its OK
i will test (but the father in law is here and cracking the whip getting me doing jobs around the house!)
Tell the father-inlaw the fishing’s great at the moment ( snapper are spawning in the Firth of Thames )
then maybe you’ll get some real work done :wink:
WIN 98SE 56K Dialup modem.
(Upload of files to web page only. NO NOAA download! NOAA downloads fail always with dialup. May be NOAA’s FTP server and not WD FTP.)
list of files uploaded*
D:\PROGRAM FILES\WDISPLAY\webfiles\BFCweather.html
D:\PROGRAM FILES\WDISPLAY\webfiles\BFCweather.gif
D:\PROGRAM FILES\WDISPLAY\webfiles\summary.gif
Open port
Port opened
Connect device
Device connected
Authenticate
Authenticate
Authenticated
Logon network
Connected
Finshed email agenda, and more Internet agenda items to do…
Logging onto FTP server…home.mindspring.com
Connected.
220 FTP server ready
USER [email protected]
331 Password required for [email protected].
PASSWORD=****
230-
230- Your disk quota is: 10.00 megabytes
230- Your disk usage is: 0.41 megabytes (4.09% of quota)
230-
230 User [email protected] logged in.
TYPE I
200 Type set to I.
CWD www
550 www: No such file or directory
141: 550 www: No such file or directory
Checking for next FTP agenda…
Doing ftp upload
Checking there are files to upload
There are more files to upload
PORT 165,247,135,74,4,5
200 PORT command successful.
STOR BFCweather.html
150 Opening BINARY mode data connection for BFCweather.html.
PORT 165,247,135,74,4,6
150 Opening BINARY mode data connection for BFCweather.gif.
PORT 165,247,135,74,4,7
150 Opening BINARY mode data connection for summary.gif.
No more files to upload
All Agenda complete, doing FTP log off…
FTP logoff
QUIT
221 Goodbye.
Disconnected.
(…Modem does not disconnect at this time…)
Open port
Open port
Open port
Open port
An operation is pending.
Disconnected
(…Disconnect ok, exit ok, and quickly…)
BTW
The FTP failures are not a problem for me. I use the old default FTP program when it matters to me and I don’t attempt a NOAA “Forecast” download when using a dialup connection.
:wink:
the waiting 20 seconds…do you have password remembered in your dial up networking?
Yes, the password is remembered in DUN, FTP, Weather Display. I don’t believe the 20 sec wait is any problem. I think it is just MS DUN or WIN 98SE.
BTW , here is my system info:
Microsoft Windows 98 4.10.2222 A
Clean install using /T:C:\WININST0.400 /SrcDir=C:\WINDOWS\OPTIONS\CABS /IS /IW /IQ /ID /IV /IZ /II /NR /U:xxxxxxxxxxxxxxxxx
IE 5 5.50.4807.2300
Uptime: 0:06:25:44
Normal mode
On “OEMCOMPUTER” as “Default”
IBM Corporation
GenuineIntel Intel(r) Celeron™ Processor
192MB RAM
44% system resources free
Windows-managed swap file on drive C (7282MB free)
Available space on drive C: 7282MB of 9051MB (FAT32)
Available space on drive D: 6742MB of 10007MB (FAT32)
Lucent Win Modem on COM 2
LT V.90 Data+Fax Modem Version 5.44
WINSOCK Information
Version: : 2.2
Description: : WinSock 2.0
what about internet sharing, under connections
that should not need be ticked
check that is not
what about internet sharing, under connections that should not need be ticked check that is not
No, internet sharing is not checked.
hummm
i wonder why the delay then…
