Weather Display has a setting to set the frequency of ftp for sending info for Weather display live. At present the shortest time between ftp’s is 5 seconds.
The new WDL version 2 you can set the polling for the data file at 3 seconds.
If WD sent the info every 3 seconds instead of every 5 seconds it would make the needle movement smoother otherwise setting the polling to less than 5 seconds in weather display live has no purpose.
It would be nice to see the option for ftp frequency be allowable at less that 5 to be compatible. (unless there is some technical reason that it is not possible)
Hello,
for me it make sense to upload only every 15 seconds because the wind is transmitted from the wind sensor every 15 seconds and the other sensors around every minute. This because it’s wireless sensors.
Cheers. :roll:
I guess that would be a restriction if one has a wireless station, however, if one has a wired station and the sampling is done every minute, I think the only restriction would be the lenghth of the file that is being ftp’d and the internet connectivity speed. If the speed was allowed to be the same as weather display live then it could be set according to the restrictions of each separate installation.
