Ftp error log
hi all
I ve seen this before what to do about it
ftp hangs
227 Entering Passive Mode (145,23,254,254,233,152) RETR uvverwachting.txt 425 Can't open data connection. 141: 425 Can't open data connection. PWD 257 "/pub_weerberichten" is current directory. Retrieving the NOAA file guidance_weerbeeld_kort.txt now PASV 227 Entering Passive Mode (145,23,254,254,234,159) RETR guidance_weerbeeld_kort.txt 425 Can't open data connection. 141: 425 Can't open data connection. PWD 257 "/pub_weerberichten" is current directory. Retrieving the NOAA file guidance_weerbeeld_lang.txt now PASV 227 Entering Passive Mode (145,23,254,254,235,96) RETR guidance_weerbeeld_lang.txt Overall time out 301: Interrupted PWD 425 Can't open data connection. Retrieving the NOAA file weeroverzicht.txt now PASV 257 "/pub_weerberichten" is current directory. Unexpected server reply. Ftp down error 141: Finished ftp download QUIT 227 Entering Passive Mode (145,23,254,254,236,208) Disconnected. Finshed email agenda Finished email agenda, no ftp items to do... Doing abort procedure/program close...
ERROR: 101: You cannot change the RemoteHost at this time. A connection is in
progress. at time/date 0:00:00 30-12-1899
my leech.ftp program has no problems to download
without any password or login
425 Can’t open data connection.
141: 425 Can’t open data connection.
what does this mean?
thanks
hi all
ftp hangs
thanks
The 425 error means that the data channel is blocked or closed between you and the server you are trying to connect to.
For Active connections open ports 20 and 21
For Passive connections open ports 21 and 1024+ (and higher)
Also, turn off command filtering on the firewall.
If you still cannot get a successful connection check all devices that are between the client and server to ensure that the proper ports are open (e.g. routers).
FTP Return Codes in Numeric Order
110 Restart marker reply. In this case, the text is exact and not left to the particular implementation; it must read: MARK yyyy = mmmm where yyyy is User-process data stream marker, and mmmm server’s equivalent marker (note the spaces between markers and “=”).
120 Service ready in nnn minutes.
125 Data connection already open; transfer starting.
150 File status okay; about to open data connection.
200 Command okay.
202 Command not implemented, superfluous at this site.
211 System status, or system help reply.
212 Directory status.
213 File status.
214 Help message.On how to use the server or the meaning of a particular non-standard command. This reply is useful only to the human user.
215 NAME system type.Where NAME is an official system name from the list in the Assigned Numbers document.
220 Service ready for new user.
221 Service closing control connection.
225 Data connection open; no transfer in progress.
226 Closing data connection. Requested file action successful (for example, file transfer or file abort).
227 Entering Passive Mode (h1,h2,h3,h4,p1,p2).
230 User logged in, proceed. Logged out if appropriate.
250 Requested file action okay, completed.
257 “PATHNAME” created.
331 User name okay, need password.
332 Need account for login.
350 Requested file action pending further information
421 Service not available, closing control connection. This may be a reply to any command if the service knows it must shut down.
426 Connection closed; transfer aborted.
450 Requested file action not taken.
451 Requested action aborted. Local error in processing.
452 Requested action not taken. Insufficient storage space in system.File unavailable (e.g., file busy) etc.
500 Syntax error, command unrecognized. This may include errors such as command line too long.
501 Syntax error in parameters or arguments.
502 Command not implemented.
503 Bad sequence of commands.
504 Command not implemented for that parameter.
530 Not logged in.
532 Need account for storing files.
550 Requested action not taken. File unavailable (e.g., file not found, no access). (550 a:: no such directory means no diskette in a: drive.)
551 Requested action aborted. Page type unknown.
552 Requested file action aborted. Exceeded storage allocation (for current directory or dataset).
553 Requested action not taken. File name not allowed.
Do you have a firewall? Have you blocked any ports recently?
hi captdilli
thanks for your complete explanation !
what happens I think is a lot of traffic to the servers here on our cablenetwork. Beside that with AntiTrojan I recovered a lot of ports were open for data or could be used for that
A lot of servers have to much datatraffic that a gt a time out
thought the problem appears only for XP users
but later on i noticed it the same for 2k so patched it
and less problem
my email server here has the same problem at the moment
it realy is a mash here
thanks to that monkeys of sobig.f and equivalents
