since today there appears the error code 530 in the ftp full log when uploading data files like synoptix.txt. :-k
the sequence is … 530 incorrect loading
If that FTP server uses standard error messages then 530 is a failed login error usually caused by incorrect username/password.
OK, til yesterday 6 pm it worked fine.
Since that time that problem exists and I made no changes in the settings since more than 6 months…
the only thing - the provider changed the server. could be found there the reason for that problem??
Roman
I think you need to contact the server folks, I would bet that it’s the change on their side that is causing the problem.
