FTP Crashes On My New Install
I have just installed WD on a Mac Mini with an Intel Chipset running Ventura.
I have Cumulus MX, WeeWX, WeatherCat and PWS Dashboard running on other machines (Raspberry Pi for the most part with WeatherCat running on the sea Mac Mini also.) So I am a little used to weather software.
WeathCat is accessing my Davis Station via a USB Data Logger and is working fine since the WD install.
I have set WD up to access my Ecowitt GW200 and this works ok producing results on WD itself.
The problem is when I try to use FTP to upload. WD just crashes.
My ISP is IONOS and I am certain I have my credentials correct.
I have set Use Weather Displays own FTP,
Port 22
Use passive
Rename the file
Use Secure FTP
These settings work with my other programs
I have tried port 21 and none secure and tried uni use /usr/bin/curl/
But it still crashes - any help would be welcome!
Hi SkyFire
I to am running WD on my MacMini and had the same issue every time i tried to FTP WD would just quit/crash i found my issue to be when WD tried to create the forcast.gif if i turn that off it uploads no issue… this may not be the same issue you are having but see if it helps if not try turning off webpage elements one at a time see if you can find the part that its crashing on… i hope this helps
Martin
