The french translation of WD is very… approximate and especially, it is incomplete. On many screens, there are some words in french and others in english on a same level of information. In others, the french words are truncated and become incomprehensible.
Could I be of any help to try to improve this French version ?
How does WD works on this point : do you have a kind of directory of all the words used in all the languages supported ?
you could use the language.ini facility
see in the help file for how to use that: http://www.weather-display.com/WDHELP.doc
but, also, let me know which things i need to change (for when you select the french language option)
no, with the language.ini, just use what is needed
if its left blank after the = , wd does not use it
so , think of the language.ini as an add to the french thats already there
