Forecasticon.gif / forecasticonsation.gif not showing moon?
Hello,
I’m using the latest demo version of WD, and I’ve found that the forecast icon, is not changing from a sun to a moon at night :?:
I have set up my own icons under the “Input Daily Weather” section, and the timezone/lat/long is all correct. It is generating the proper sunrise/sunset times.
However, the icon s never changing from a sun to a moon. It does change to the correct icon for weather (cloudy/rain/mainly fine/etc) but it always showes a sun instead of a moon.
Any suggestions?
I found the problem :smiley:
I had the boxes checked to use the forecast icons from the datalogger, rather then being generated by WD.
Unchecking the boxes solved the problem :slight_smile:
