Toggle to turn upload off and on? :lol:
Double click main screen icon. 5 day forecast will come up and at the top of the screen there will be upload to web site.
Not what I was suggesting.
What I was suggesting is an easier way of stopping the upload w/o having to erase the setup. It’s easy enough to stop is from showing on my webpage but it still uploads. If I erase the setup then want to start up again, it has to be set up again, ie selecting forecast, etc.
There are a number of good reasons to suspend upload off and on I won’t even get into, not the least of which is a slow NOAA server that hangs my uploads completely.
Weatherbee, I found what you’re talking about and that would do it. It wasn’t working because the file was uploading (takes time on a dialup) and when I upgraded to new version, it is now leaving that file out of the upload. I’ll watch it to see what happens, thanks!
BTW Brian moved the NOAA download to last and that helps too. I don’t upgrade this station often because it is remote and unattended most of the time.
