Forecast Icons
I followed the directions in the online help manual to change the icons in WD, but it is still showing the default icons. Anybody have any ideas.
Did you restart WD after changing them?
I tried that and it did not have any effect?
I was thinking of just replacing the default icons, but i can’t figure out where they are located.
humm
try this way:
go to input daily weather
then double click on the icon to change
and select the icon /image to change to
then that should work OK
ok, that worked but will it always use that ican in the future
That worked and changed the icon, but after I restarted it reverted back to the default icons. Also if anybody knows where to download some icons please let me know.
humm
it should keep that icon on restart…
do you have a folder called myicons or myicons2?
try deleting or renaming those folders
a couple of good sets of icons can be found at
http://members.cox.net/carterlakeweather/myicons.zip
http://www.tnet.com/POSTED/wd-icons-set1.zip
Thanks Guys,
I think I have it figured out. I dont what I was doing wrong last night, but it is working now.
