Greetings Ed
First, I note that the current values are inverted in the max & min columns; to correct it, you must edit the corresponding .log file.
Also curiously, I note that in the following tables there is more text:
[https://www.weersverwachtingen.eu/clientraw/wd-ajax-ml/test-fc.php](https://www.weersverwachtingen.eu/clientraw/wd-ajax-ml/test-fc.php)
I would install the original “fc-language.php” file.
See if this helps you
-Javier
Ed,
It looks like you have everything working correctly now?
Ed,
I take that back. Your copy of Ken’s script is named WC-forecast2.php but in your fc-config you have it without the “2”. Also, your fctest.php needs updating so please upload the attached after removing the .txt extension.
fctest.php.txt (17.7 KB)
Hi Jim
Nice to hear you !
Changed Ken’s forecast in the meanwhile. Cause YR and MC comparasion works fine it must be WU (WC)
Will download your suggestion tomorrow.!
Morning Jim
This is what I see (att) at that page
I miss the values of the log txt isn’t it ?
Thnx so far !!
Ed,
When I view the source of fctest.php I find the old version, so that might be the problem. Another thing you can try is to run the compare script in logging mode and see what happens. The readme file will remind you how to do that.
I see the changed version but still no luck. Please upload the two attached files, there’s a couple changes and a couple debugging lines added.
Thanks. - Jim
forecast-compare-include.php.txt (44.5 KB)
Ed,
I just noticed something that I think is causing our problem now. Still upload the files in my previous post, but also in your fc-config.php file change
$fileLoc = "clientraw/wd-ajax-ml/";
to
$fileLoc = "";
since all of these files are in the same folder.
Sorry replying late ,Jim !
Have been out for couple of weeks and now again return at 3th of June.
Will do then !
Thanks !
