First of the month crash
Recently upgraded to 10.10t. I have been having a problem with WD crashing the 1st of each month. Today was no different. I did check the programerrorlog.txt file before restarting WD. It contained 2 lines, resetting the rain total and resetting the temps.
After restarting WD I noticed the rain had been reset but not the temps. Don’t know if that helps any or not…
Dan
what weather station type?
if a ws2010-13 data logger (ws2010 station), then it will be because the log file is too big, becuase of duplicate time entries
but i have now finaly fixed that in 10.10t
and so that should not happen again
you can reset those temps hi/lo under action, reset daily extreme values…
Davis Weather Monitor II
Right on schedule, crashed overnight. Here is the contents of the programerror.txt file before I restarted WD
ERROR Unable to write to WDISPLAY.INI at time/date 150000 5/24/2004
ERROR Unable to write to WDISPLAY.INI at time/date 230000 5/24/2004
Resetting rain daily value , day 25
Resetting wind/temperature daily value , day 25
ERROR Unable to write to WDISPLAY.INI at time/date 100000 05/25/04
Resetting rain daily value , day 26
ERROR Unable to write to WDISPLAY.INI at time/date 000000 05/26/04
Resetting wind/temperature daily value , day 26
Resetting rain daily value , day 27
ERROR Unable to write to WDISPLAY.INI at time/date 000000 05/27/04
Resetting wind/temperature daily value , day 27
ERROR Unable to write to WDISPLAY.INI at time/date 090001 05/27/04
ERROR Unable to write to WDISPLAY.INI at time/date 120000 05/27/04
ERROR Unable to write to WDISPLAY.INI at time/date 130000 05/27/04
Resetting rain daily value , day 28
Resetting wind/temperature daily value , day 28
ERROR Unable to write to WDISPLAY.INI at time/date 060000 05/28/04
ERROR Unable to write to WDISPLAY.INI at time/date 130000 05/28/04
Resetting rain daily value , day 29
Resetting wind/temperature daily value , day 29
Resetting rain daily value , day 30
Resetting wind/temperature daily value , day 30
ERROR Unable to write to WDISPLAY.INI at time/date 080000 05/30/04
ERROR Unable to write to WDISPLAY.INI at time/date 150000 05/30/04
ERROR Unable to write to WDISPLAY.INI at time/date 160000 05/30/04
Resetting rain daily value , day 31
Resetting wind/temperature daily value , day 31
Resetting rain daily value , day 1
Resetting wind/temperature daily value , day 1
Dan
Hello, The same for me with v10.12q…
sorry… :cry:
FWIW, I am running 10.12q now also. And the errors in the programerror.txt file regarding the .ini file are most likely because I installed a 2nd copy of WD to use for testing and I was running both at the same time. I have since moved the 2nd copy to another machine so I can test code for Brian on importing datalogger data from the WDII console, and, maybe figuring out what causes the program to crash on the 1st of the month.
beruberu, what weather station are you running, and what OS in on your computer that is hooked to your weather station? After WD crashes, is there any useful data in your programerror.txt file?
Perhaps we can find a common point that will help narrow the problem area down…
Dan
Dan
Ws 2210 with Windows XP
nothing in txt file…
It is not the first time I have this trouble… but it makes a few monthes that it didn’t happen…
Have a nice day or night… it depends… :wink:
dcrooks:
if you have a file called 2wd.txt with that 2nd installation, then it uses wdisplay2.ini
and so you should not get any conflict with the wdisplay.ini file…
strange…
re the davis wmii data exctraction:
one thing that will cause grief is the fact that the time/date entered in the ini file for when to extract data from was only being updated if you exit wd via exit, save and exit
i have changed it, to have it update each minute,in a new 10.12r, other wise if wd crashes, it doesnt get updated…aqnd at start up, its trying to download data from along way back…
i have also done a few tweaks with the davis wmii data extraction that might help
Yes, both of these files are present. But I can’t explain the error being generated by my primary installation unable to write to the .ini file.
I will give the new 10.12r version a try and see what happens.
Any idea about the 1st of the month crash?
A follow-up to my earlier post since I switched to 10.12r. It has been a couple of days and the contents on the programerror.txt file now shows:
ERROR: Unable to write to WDISPLAY.INI at time/date 14:00:00 6/3/2004
ERROR: Unable to write to WDISPLAY.INI at time/date 19:00:00 6/3/2004
Resetting rain daily value , day: 4
Resetting wind/temperature daily value , day: 4
ERROR: Unable to write to WDISPLAY.INI at time/date 13:00:00 06/04/04
ERROR: List index out of bounds (0) at time/date 13:36:28 06/04/04
ERROR: Unable to write to WDISPLAY.INI at time/date 19:00:00 06/04/04
Resetting rain daily value , day: 5
Resetting wind/temperature daily value , day: 5
ERROR: Unable to write to WDISPLAY.INI at time/date 03:00:00 06/05/04
ERROR: Unable to write to WDISPLAY.INI at time/date 04:00:00 06/05/04
ERROR: Unable to write to WDISPLAY.INI at time/date 08:00:00 06/05/04
These errors are coming from my primary WD connected to comm port to the WMII console and contains ALL my historical data. The 2nd copy of WD (running off server) programerror.txt file looks ok.
While I wait for you to find time to work the datalogger problem I need to know if not writing the WDISPLAY.INI is going to cause me problems, or if I should ignore the errors?
Dan [-- waiting for the 1st of the month to come around again --]
i have it reported and confirmed that 10.12s fixes the data extraction from the davis wmii (see my post in the bug reports)
as for the error with the wdisplay.ini file, i am not sure, but it must be some conflict occuring at those times…
do you have any antivirus or protect software running?
5 6 2004 14 7 85.6 27 47.8 29.940 1 3 304 0.000 0.000 0.000 11.140 83.0
5 6 2004 14 8 85.7 27 47.9 29.943 1 3 301 0.000 0.000 0.000 11.140 83.1
5 6 2004 9 15 67.1 54 49.9 30.005 1 3 360 0.000 0.000 0.000 11.140 77.3
5 6 2004 10 0 70.3 48 49.7 29.995 1 3 135 0.000 0.000 0.000 11.140 77.0
5 6 2004 11 0 76.2 42 51.5 29.986 2 6 22 0.000 0.000 0.000 11.140 78.0
5 6 2004 12 0 80.3 36 50.9 29.971 2 7 315 0.000 0.000 0.000 11.140 79.8
5 6 2004 13 0 82.5 33 50.5 29.953 3 9 270 0.000 0.000 0.000 11.140 81.1
5 6 2004 14 0 84.8 30 50.0 29.941 3 9 292 0.000 0.000 0.000 11.140 82.7
5 6 2004 14 31 86.4 27 48.5 29.934 2 9 204 0.000 0.000 0.000 11.140 83.8
– Looks better than it was before…shut down WD from 14:08 to about 14:30 while I installed 10.12s and rebooted the machine –
Yes, wouldn’t run without it :smiley:
as for the error with the wdisplay.ini file, i am not sure, but it must be some conflict occuring at those times....
If the above data looks okay for the import I don’t need to run the second copy of WD anymore. I should mention that the graphs show a spike in the data and are grayed out for the period I shut WD down. Is that normal?
Is there anything you want me to do in regards to the first of the month crashing of WD? Am I the only person having this particular problem??
Dan
Right on schedule, July 1st and WD crashed. Contents of programerror.txt::
Cannot create file C:\Program Files\Creative\Video Blaster WebCam Monitor\Cache\webcam.jpg
Resetting rain daily value , day: 1
Resetting wind/temperature daily value , day: 1
Is anyone else having this problem??
[Note] The ‘Extreme conditions Values’ were not reset.
Dan
Running 10.13i
Went into
  • Action
    • Reset Daily Extreme Values
      • Do the daily reset now
And WD crashed. Tried it three times and WD crashed all 3 times. I then tried the Reset ALL and that appeared to work.
Dan
humm, no problems here, and no other reports of problems…so far
hummmmm
humm, no problems here, and no other reports of problems....so far hummmmm
sorry , but this morning WD crash again I’m using V10.13j
Sorry have a nice day… :cry: :cry:
ok, but you are with the ws2010 type station, which it looks like still has a end of month problem (to do with the log file size (zip and email me the log file 62004lg.txt, thanks))
,whereas dcrooks has a davis wmii, which should not have the same log file size issue…
Might be in the daily reset. Is there a way to turn on debugging for that?
Dan
was the next daily reset ok?
Nope. I noticed the values were not reset when I rebooted, so I went to…
  • Action
And WD crashed. Tried it three times and WD crashed all 3 times. WD simply disappeared everytime I clicked it. No log entries were made.
I then tried the “Reset ALL” and that worked.
