I added a new Fire Weather Index page to my site: www.thanko.info/fwi.php.
Can anyone give me an idea if the numbers look right?
Grand Rapids, MI
Grand Rapids, MI
Tim, not sure about your numbers but have you checked it by going to the WFAS website and looking at the map data for the closest station to your location?
http://www.fs.fed.us/land/wfas/fdr_obs.dat
This will give you the KBDI and fire index
Robin
And this appears to be your nearest RAWS station. It has a couple of fire weather related parameters on it. Not sure if you can make any correlations between this and your FWI.
http://www.met.utah.edu/cgi-bin/droman/meso_base.cgi?stn=BDLM4
From the looks of the predictions map I suspect you should be in the moderate range. Things must be fairly dry in your area. Whens the last time you had significant rainfall?
Actually I think he should be in the other extreme…wetter than normal.
See:
http://www.cpc.ncep.noaa.gov/products/analysis_monitoring/regional_monitoring/palmer.gif
and
Yep your right…I should have checked the keech-byrum index.
