Just to clarify, 0 on the leaf wetness is dry 1-15 indicates moisture on sensor, with 15 being the wettest.
Currently because of early morning and high humidity, WD is indicating Moderate Rain.
Cheers
Cyclone
hi Brian,
thats not a good idea because it is no more working for me!
I have a heating (foliage) put at the other side of the leaf wetness sensor - so there is no dew registrated, because it is always dry, exept when it is raining!!!
Suggestion:
a custom setup for setting the number of the leafwetness, when it should say it its raining
(1-15)
why dont you put a heating foliage at the back of the leaf wetness sensor? So dew never will be registrated …
its very simply and it works for me here.
yes, that could be an option, to add another station.
if that is no trouble with Brian.
i would still like the 0-14 scale for farming reasons, but a 15 only for rain sounds good.
Cheers
Cyclone
Hi cyclone,
I have a heating foliage with 12 Watt in use, which I located at the back side of the leaf sensor.
It is combinated with an transformator to a voltage from 220 V to 9V. (it must be on 24 hours all days)
I made good experiences here with that solution even in summer and also in winter.
Do you have some more question, let me know.
Finally installed the 18 watt heater on the 2nd leaf wetness sensor, fits perfect on the back.
just have to wait for some light rain. ( did some cheating today, with a hand sprayer )
Brian, is there a drizzle icon ?
[quote author=cyclone link=topic=5565.msg95415#msg95415 date=1132637016]
How about a bit of a modification to the logic, where the sesnor could indicate rain if it is wet but unless there is a bucket tip within x minutes (however long it would take a “light rain” to generate .01" of rain)to confirm it the details and logs for rain get cancelled, or is that too difficult to implement. In that way the rain bucket tip would do all the rain indication with the wetness sensor only being used to indicate the start of light rain.
[quote author=trevor link=topic=5565.msg95453#msg95453 date=1132670223]
Seems sensible except it doesn’t appear to work correctly with high humidity without adding heaters to the leaf sensor. This way may be more reliable for us as users. But may be a nasty job. or impossible, to implement.
[quote author=trevor link=topic=5565.msg95477#msg95477 date=1132685269]
