Failed to import Davis logs
I have tried unsucessfuly to import the Davis “download.txt” data file into WD. I’m running v10.16r. I’m using a Vantage Pro with WeatherLink 5.5. I exported several different versions of the data set (larger to smaller file sizes) to various text files. The data set I’m using is metric based.
When any of these text files are imported into WD, the process doesn’t seem to exit properly in that the red “importing data” text does not clear from the dialog box and there is no increase in either the number of files in the WD directories or the size of any existing files. Saving and exiting does not have any effect. I have tried different file names and sizes, ranging from as small as a few hundred KB all the way up to 45 MB with no success.
Help!!
Thanx in advance,
Craig
email me the file , and i will see whats up and try it from here
