Is it possible to extract the data file data and load it into a file that can be graphed using one of the several external graphing options that are available such as “OFC, sparkline or JPgraph”
The reason I am asking is I would like to graph the voltage from my one wire solar sensor and place it on my graphs page. I know that the data is in the data file because you can graph it on the WD extra sensor graphs.
Try making the customtext.txt file a single line with everything on one line, also make sure you dont have it called customtext.txt.txt which is a favourite error when using notepad and having file extensions hidden. Also ensure it is in your correct webfiles folder where all your web pages etc are created.
Well I changed the file so that is is all on one line and verified that I had not .txt.txt the files and they were not. Still no output to the customtextout.txt
Disregard I did some messing and it is know logging
I changed the file name of customtextout.txt to custom textout.txt and it started logging and changed the file name back to customtextout.txt In the web files folder
