Extra sensors on LaCrosse 2010 -- again
this is a repost. Not sure if the other got thru.
Brian, I have installed and am using 10.15z and the extra sensors are now showing up on the client. The problem now is that the Humdity, on the client, is only recording and displying the first digit. 7% instead of 72% for example.
Also I put one of the sensors in my attic which runs 25 to 30 degrees above the outside temp. I have it graphing on the main graphs. It is set to graph it’s temp vice indoor temp. I can’t get the temp scale to go above 104 without setting it to use the outside scale. Is 104 a default max for inside temp?
Begin brownosing:
I have resisted PayPal for the past several years for various reason, but have just set up an account so I can show you rather than just tell you how much I appreciate the help you have given. I hope others will do the same. I’ve spent more time on hold with some companies than it has taken you to fix a problem and post an update. I’m not saying this to get you to look at the above because I have no doubt you will look into this no matter what I do. Thanks again.
yes, the original post worked, and i have replied …here was the reply:
thanks for the donation!
yes, there is a limit for the indoor…but try the option of ticking set the indoor temperature to the outdoor temperature (not sure if that applies to max indoor temperature scale though…if not, let me know)
client humidity…
i might have to add some debug code…and i will check here with my server and its extra humiditiy sensor////soon (after i catch up on emails/forum postings)
