Extra sensor realtime graph problem
I’m having a problem where the “extra sensor realtime” data will go off the chart (say, from 68F to 718.5F!) for no apparent reason. All the time, accurate data is arriving from the sensors (as seen on the 1-wire setup page). The bad data will stay on the graph indefinitely.
In order to clear it, I have to uncheck the sensor in the extra sensor graph setup, exit setup, re-enter setup, and recheck and set it. That seems to ususally fix it, although sometimes I need to clear the data completely.
Any idea what may be causing it? I don’t think its a sensor problem because the readings are continuous and error-free on the “1-wire setup” page.
Rich
ps - the normal “realtime” graph does not have this problem. One sensor (1-wire used as indoor) which crashed on the “extra sensor” graph continued to report correctly on the regular realtime graph…
that points to the value going out of range of the graph…i.e above or below the graph max/min value…
try changing the minimum offset maybe?
I was starting to think that may have happened myself. i just widened all of the ranges – I’ll let it run a while and see. Thanks!
