Extra sensor graph on 10.13k
Hi Brian
some items i have noted with this graph see notes below
while viewing the above graph it appears to pulse this appears to be because it is trying to display the right hand side of graph on the left hand side of graph tried to screen capture but i am not quick enough.
if you run the mouse over the graph the values under the labels change except the i have marked mast temp this only changes when the temp changes
the mast humidity is ok when moving the mouse over the graph but changes to a temp when left as shown but is showing % on the web uploads
sliding scales seem ok
my bad
uploading a fix now, as fresh version
Thanks Brian
what happened is i had intended to have the data refreshed each minute…
but i forgot to set the timer i added to 1 minute…the default is every second
a silly mistake on my part
Hi Brian
ok i have had a chance to check the update out and pulsing stopped but any clues as to
if you run the mouse over the graph the values under the labels change except the i have marked mast temp this only changes when the temp changes the mast humidity is ok when moving the mouse over the graph but changes to a temp when left as shown but is showing % on the web uploads
this is still happening
a new 10.13k
ready now
should fix that issue
thanks
nearly there with this one only thing not doing anything is the mast temp value under label on right slider moves ok when mouse moved over graph.
some time ago i changed the colour of the mast temp plot to the colour you see in the image at begining of this thead but the label also change colour which i would preferr to be default white, how do i change the label colour without changing the plot colour.
version 10.13p seems to have sorted the temp changing while moving the mouse over it i.e. it now changes ref mast temp on mine.
the mast humidity seems ok but i have noticed while viewing it a temp value is displayed for the odd second rather than a % value this not a problem when viewing on machine but when the web file is created the value is always a temperature value.
extrarealtimegraph2 has a problem with the units and channel coloums in the middle over lapping
i will do more work on this today…
i must be nearly there!
(after a major revamp of that graph)
extra info
the value i refer to is under the label mast humidity when you look at the extrarealtimegraph on web page
and yes finishing line in sight on this one
ok, looking good…just that one little mistake
i will look and fix and update now
(and fix that windchill thing you noticed ( i will redo what i had done)
also, i noticed you are not using wdl 1.08… you will need that for the strong winds heading your way!
i have found the problem
uploading 10.13t now
also, i have fixed up the 2nd mesomap (for the use of wunderground stations), and also fixed a IO error with the use of that map too
ok Brian will wait till i can download 13t before upgading both units
have now upgraded wdl to 1.08 but hopefully the wind will not be as bad as it was down the south of england today had a sunny day here on Isle of Man
now updated to version 13t
http://www.hc-iom.co.uk/weather/extrarealtimegraph.gif
now ok
http://www.hc-iom.co.uk/weather/extrarealtimegraph2.gif
still a problem with labeling on bottom below graph
