Extra sensor confict with labjack
I’m not sure if this is a bug or I’m doing something wrong and need to change my settings.
I have an WMR928N with three extra sensors (2 temp / humidity and one temperature probe). I have now added a LabJack with a simple solar sensor and 2 extra temperature probes, (Labjack sensors 5, 6 and 7).
The LabJack seems to override the 3 WMR928 extra sensors. However there are times when they read correctly and times when they show the current estimated Labjack temperatures. Strangely the wmr928 sensors graph correctly.
Here are the current temperature tags from my system. Sometimes the extra temp tags show the WMR928 figures and sometimes the LabJack figures
244.6
-59.9
-129.6
-100.0
-100.0
34.5
9.1
-100.0
244.6
-59.9
-129.6
-100.0
-100.0
34.5
9.1
18.6
5.7
10.0
ah, yes, i forgot to reply to your email
what I will have to do is add in wd where you can set which extra sensor numbers to allocate to the labjack sesnors
(i.e so you have the labjack sensors as extra temperature 4 5 and 6
Brian
Many thanks,
I have a workaround using xml tags on my webpage to overide the spurious settings, so there is no particular urgency for this.
done this, you can set those settings in the labjack window (setup,i have a lbjack, view the readings)
in a new 10.19y, uploading now, ready soon
Brian
I’ve downloaded the new version and all is working OK now.
Many thanks
