EWN scripts for Leuven Tamplate. Help possible?
Hi.
I signed up my station at EWN http://www.europeanweathernetwork.eu/member.php?en
thinking to install the script describen here: http://wiki.leuven-template.eu/doku.php?id=ewn
I have followed the instruction but nothing shows. Is it possible to use the “debug” function to see why?
vindpropell.no
I have installed all three scripts. “Members page”, “Weather maps” , “European wide forecast”.
All EWN scriptys are already fully installed in the Leuven-Template.
No need to install anything.
My own site show all EWN scripts operational:
Forecast: http://www.weerstation-wilsele.be/index.php?p=ewnFctHead2&wp=MH&lang=en
Members: http://www.weerstation-wilsele.be/index.php?p=32&lang=en&wp=MH#data-area
Maps: http://www.weerstation-wilsele.be/index.php?p=ewnMapsBody2&lang=en&wp=MH#data-area
You can check the other European user sites also, most of them are EWN members.
Just change the setting for EWN to true in wsSettings.php and all should be available at your site also.
WiKi
First check if the script in the Leuven-Template download is the recent one.
Goto menu choice Mesonets ⇒ europe ⇒ www.yourwebsite.com/weather2/index.php?p=32 and check if the page displays correctly.
If so you can skip the download part of this install-instructions.
If one has messed up wsSettings.xml, is it possible to owerwrite it with the original wsSettings.xml file?
Is seems that many links in the menu is missing. Among others, the EWN script.
I have not deleeted anything, just messed up the menu structure in wsSettings.xml.
Yes, you can overwrite with an original, it will not hurt, it will just revert it back to when it was brand new so to speak :slight_smile:
Thanks. :wink:
The menu entries in the menu the visitor (also you) see are based on the settings. So optional menu entries appear only when the corresponding setting in wsSettings.php is set to true.
Line approx. 573
$SITE['ewnID']		= true; 			// #####
As long as that line is not set to true, there will be no EWN menu entries.
Same for optional forecasts and so on.
WiKi http://wiki.leuven-template.eu/doku.php?id=menu describes this using the show=“” parameter.
So EWN menu entries have show=“ewnID”
I hope you refer to wsMenuData.xml in your previous post as there is no wsSettings.xml only a wsSettings.php
That wsSettings.php one can not be freshly uploaded as you will lose all settings. you made.
I suddentli rememberd that I took a copy of the whole weather2 folder, a cuople of days ago,
so I have deleeted the template on the webserver because something was seriously wrong.
Hope it works again when I have uploaded the backup folder.
Ahh- I see now that I had set many if the ID to “false”. :slight_smile:
Yes!
The backup seems to work. Every page works now exept the “YR no forcast ditail” in the tab, “Forcast”. (That hasn
[quote author=tobydude link=topic=60379.msg481738#msg481738 date=1430862431]
Yes!
The backup seems to work. Every page works now [color=red][b]exept the “YR no forcast ditail” in the tab, “Forcast”. (That hasn
I understand. It
[quote author=tobydude link=topic=60379.msg481772#msg481772 date=1430903828]
I understand. It
It works now,after changin to “true”.
If you want the page without the javascripts “chartsMeteogram” you can set
$chartsMeteogram	= false;	        // high charts meteogram -
after a download and installing of an updated version of startLeuven.php from the problems page at
http://leuven-template.eu/problems.php?lang=en
Not Found
The requested URL /yrno_startLeuven.zip was not found on this server.
It is now,
Everything seems to work now. The Yowindow, Yr, webcam, WDL and the EWN shows the lokal weather here at my station. vindpropell.no
There are only a few minor “issues”.
How to get rid of the “Precipitation Radar” tab that doesn
[quote author=tobydude link=topic=60379.msg481798#msg481798 date=1430919886]
