Error on main graph
Temperature graph not recording correct temperatures:
The temperature is 89.3 but the graph is showing the temp at nearly 100.
Greg, I have had this problem before and it has corrected only after the midnight rollover. The cause has usually been due to the errors in my 1-wire data (errors from the DS9097U).
I think there is some problem with WD where it has difficulty dealing with data problems.
8.94e fixes that
