Error message on startup WD
when starting WD I get the following error-message on the right side of the WD-Display
ERROR Read beyond end of file at date/time…
Nothing more happens with WD!
What does that mean?
Peter
when starting WD I get the following error-message on the right side of the WD-Display:
ERROR: Read beyond end of file at date/time…
Peter
What version of WD are you using?
What version of the FTP are you using?
What is your operating system?
Are you using a desktop or laptop computer?
Are you using a screen saver?
Try:
go to action, import log files
then covert WD log files to graphs
then select the log file
32003lg.txt
and click on convert
then try restarting the program
if that fails, delete the file latest.inf from the folder datafiles
and restart the program
are you upgrading from a very old version?
Brian,
the logfile-conversion did it, thanks!
I am using Vers. 9.68, did not upgrade, Windows 98 SE, no screensaver.
Peter
