Error loading records.
Just upgraded an rather old installation (WDL 1.04).
I am now running WDL 2.04 and WD 10.17v.
Both clientraw.txt and clientrawextra.txt is created but for some reason
when “Records” is pressed (after 20 sec of loading) this error pops up: Error Loading Records.
Any suggestions.
Regards
what is the URL
so we can help you out to see what you have done, etc
Yes post the URL and we’ll have a look!
Julian
I’m getting the same thing. I haven’t been running the WDL most of the day and don’t recall the last time I tried push the Records button.
Seems some of the charts are missing too. but I can’t think of which. There used to be a scroll bar worth of them, no scroll bar now.
Direct link:
http://weather.got-there.com/kazmesa12/wd/wd-live.html
http://weather.got-there.com/kazmesa12/wd/wdlconfig.xml
try setting the location of the clientraw.txt and clientrawextra.txt files in the config xml file, as I have noted above
Hmm. I did make a slight change to the records loading routine so it looks like I’m going to have to tweak it again for the next release. The 24 hour graphs are part of the data in the records information so they won’t appear if the records haven’t loaded correctly.
Julian
The 24 hour graphs are part of the data in the records information so they won't appear if the records haven't loaded correctly. Julian
This was not a problem before. Do you know what the cause is?
I used to be able to see 24 hour charts.
Yes, found the problem. New version will be released later tonight.
Julian
vers 2.05 is ready now to download to fix this
