Error loading records
After I install WD 10.17v I cant display “Records” from WDL (2.04)
And all 24h graphics is missing too.
br,
Eki
the wdl congif xml file needs to be set to point to the location of the extra data file
try that
i.e
http://www.antto.net/saa/clientrawextra.txt
i.e set that in the config xml file
i.e in
http://www.antto.net/saa/wdlconfig.xml
see the tags to set the clientraw and clientrawextra locations (set both)
i really like your flash layout, well done :slight_smile:
also, what vers of wd?
I change wdlconfig.xml that way > Nothing change. All 24h graphs is still missing and “error loading records”
Then I uninstall WD 10.17v and reinstall 10.17u > All works fine!
Then I install newest version of WD (.17w) > All 24h data is missing again :frowning:
And one more time I install WD 17.u and all works!
Are you do some “undocumented” changes between version .17u and .17v?
You can see difference with these two crawxtra-files. First file is ok (generated WD version .17u) but second is generated version .17w.
http://www.antto.net/saa/clientrawextra.17w
ok, yes, its the extra data in the clientrawextra file that is the problem
Julian has sent me a new WDL, 2.05, to fix this
ready soon!
2.05 is ready now
I upgraded both and now the 24 hour charts work and records.
10.7w and 2.05wdl
I upgrade both too and now all work ok! (WD 10.17x and WDL 2.05)
Thanks again Julian and Brian!
That third color is good renewal!
Cheers,
Eki
