Error Loading Configuration
All,
I was running Weather Display Live version 1.05 Just fine. I am a registered owner of Weather Display Live. Today I just downloaded and installed Weather Display Live 1.08. Every time I go to the webpage it sits on Configuring… and then says Error Loading Configuration. The web page is http://cessnaskyhawk.com/weather/index.html.
Please give me some advise on how to fix it. Thanks.
Andrew Hale
Looking at your source code you’ve specified that your clientraw file is at http://cessnaskyhawk.com/clientraw.txt. WDL takes that information and looks for the wdlconfig file at http://cessnaskyhawk.com/wdlconfig.xml. However neither of those files appear to be at that location.
Julian
yep that is probably it. Not sure what I was thinking when I installed it. Will fix it now.
Andrew
its OK now
(strangely i got a warning about being insecure from macromedia)
strange, I am a happily married man!
Yes that’s happening because the clientraw/config is on a different domain - it’s got a www in front of it. Interestingly Flash used to prohibit this completely but the latest version offers a prompt if you want to accept it or not.
Julian
