Hi guys and girls
I just downloaded the WDL 1_08 and I changed the lines in the index.html, but stil I get an “error loading configuration”, does anybody have any ideas
Can you post the address of the page with WDL on it and I’ll have a look?
Julian
also, i see there is a problem with the large images on your web site
try:
setup, use large screen size, and then click on Yes again
and then restart wd
http://home1.stofanet.dk/bdittmer/index2.html
i have found this web page
but you have not changed where it says mywebsite to what your domain name is, etc, in the index2.html file
oh, i found the correct URL
http://home1.stofanet.dk/bdittmer/weather/wdlconfig.xml
thats the problem
the config file does not have the serial registrtion number in it…
instert that, upload that file, and it should be OK
http://home1.stofanet.dk/bdittmer/weather/ loads fine for me. As Brian says you just need the serial number.
If you want to get it working on the http://home1.stofanet.dk/bdittmer/index2.html page you must amend the web page so WDL knows where to get the clientraw file from.
Julian
Yahoo I got it to work, how I dont know?
good news
