Error code
I get the following when i start the program
screen comes up, tries to talk to davis, then in the white window
error:access violation at address 0059159e in module “weatherd.exe”.read of address ffffffff at time/date
any clue? it works sometimes?
andy
which davis station
what version of weather display
this is when its doing the data extract at start up?
It is a
Davis Weather Monitor.
Version is 9.94e (just upgraded, same problem)
Program loads fine and works fine. Just when i run it I get the error message where the graphs should go.
I think the install my have got corrupted, since it ran clean before. Is there a way to completely uninstal everything and start over. All the registry keys, misc files in the windows directory, etc. Then i could reload everything from scratch. I tried to uninstall, reinstall, but it does the same thing and remembers my original factory settings.
Andy J
yes, try:
install the latest verison to a new directory
then create a file there called
2wd.txt
i.e save something in notpad.exe as 2wd
then wd will start there as brand new
set up com port, station type, etc
then once going ok, exit, then copy across the logfiles, datafiles and webfiles folders
then try again
if still going ok, back up wdisplay2.ini then copy wdisplay.ini to wdisplay2.ini in c:\windows or c:\winnt
try that much
That worked. Thank you for the prompt and good advise.
Andy :slight_smile:
Grasshopper act to fast to celebrate and praise 8O
I rebuilt the page, got everthing dialed in, cam, graphs, pages etc. Worked great, looked great. I rebooted and poof same error access violation error.
All of the boxes are blank and no data is being recieved. I go back set the com and unit, but still same dam error…
Next idea?
Thank you.
Andy
email me your settings, wdisplay.ini from c:\windows or c:\winnt
and
wdisplayftp.ini from the registyr
I upgraded to windows xp, seems to have fixed the problem, and a few others…yea.
for some reason i cannot get reliable uploads for the webcam though. It seems to not be registering the changes made in teh view/webcam/ set up. I change the file upload in the setup/webcam page, but it still uploads a gif, when I want a jpg, and have that selected.
Very puzzeling and frustrating. Is there a way to view the settings in one place. ie, what webcam type is going to be uploaded? and what is teh index page going to expect?
aj
can you provide a screen shot of where you are in the program and which part is not working?
thanks
or, export and email me your wdisplayftp.ini settings from the registry
see here for how:
http://www.weather-display.com/exportregistry.html
