I just purchased a Mac and setup the Weather Display on it. I have used the PC version for a while. When we have snow, I click on the top menu bar and select Input Daily Weather. Then I go to Todays Snowfall and input the inches and click ok. I did this both on 11/26 and 11/27. However, the following day I check on this and while it input my data correctly, its showing up on wrong dates of 11/15 and 11/16 not the dates I actually entered them on. How do I get this corrected and how do I get future entry to be on the date I entered them? Thanks
This is the fix which I got directly from emailing the regular support. It seems nobody in the forum had the answer so I am posting it for anyone else with the issue. This happened only because I installed the software mid month so it did not have 30 days of data. Therefore, the snow amount would be on the wrong date.
its most likely i suspect that the logfile for snow data is out of sync
i,e
the logfile
for November is
112024lg2.txt
in the WD logfiles folder
(get to that directory via the about menu)
make sure there is the correct number of days lines (i.e 30 for november), i,e add missing ones
