Dry and raining???
Do you folks have the same problem?
It was written Dry in the top middle of display with the Rain Icon on the top right.
Thanks. :?:
v2 takes it’s information both from the current conditions text and from the ‘sync icons’ feed from WD. The sync icons must have been overriding the text for some reason.
Julian
maybe wd has icons updated by the metar…
(try ticking, you stations wind/rain over rides the metar, in the summary image and icon setup)
I have the same problem, and as far as i can tell, i DO NOT have update using local metar checked. I am using my webcamimage as my current conditions ‘icon’…I hadn’t reported this yet as I was monitoring and double checking my settings…
Trev
the thing to so is see what is reported in the clientraw.txt file, i,.e the icon number and the conditions report (refer to the cleintrawdescription)
Do you have a leaf wetness sensor ?
Cheers
Cyclone
Here are my settings. This screenshot has been compressed.
Thanks again. :slight_smile:
To cyclone: No, I don’t have a wetleaf sensor.
Is the icon in WDL supposed to show forecasted weather or actual weather?
Thanks. :oops:
Actual
Julian
actualy, becuase you have set the icons to be udpated by the VP forecast, that will be coming through to WDL i think
(maybe I need to set for that not to happen)
Also Brian, the Use the Leaf Wetness from a Davis VP or Grow station to sset the rain icon is working great, BUT requires some fine tuning.
  • only show the rain icon if sensor reaches 15
  • only show rain icon if sensor reaches 0 to 15 less than, lets say 3 minutes,
Currently on my backup system its says its raining, because the leaf wetness sensor is not 0.
Cheers
Cyclone
