Download metar
Ciao Brian,
Why can’t download more than 50 metar?
Can’t you remove that limit?
Second question: is it possible to download the synop metars? The difference is that by synop you can get precipitation data too.
Thanks and ciao.
Tuono
do you mean 50 for the custom tags?
synop:
i have now enabled where you can use one of these asos/synop metars to update wd;s data (under setup, US navy metar), and it will use the rain data (hourly P position), but i will add option to populate the gif image(s) and custom tag data with the data from one of these metars too
Yes Brian, i mean more than 50 for custom tags.
Ciao.
Tuono.
how many did you want?
is a lot of work for me, and it uses more memory (and wd is already memeory hungry :frowning:
Ok, let the tags 50 for now. In case of problems will mail you again.
Ciao, Tuono.
you could run a 2nd vers of wd in another directory with a 2wd.txt file to get 50 more that way
i will get wd to use a synop metar soon…
just working on accounts/book work at the moment :slight_smile:
Ok, ciao and thanks.
Tuono.
