Does the language.ini change with new versions?
Hi, I’m wondering if the language.ini does change with new versions.
When I have translated it, can I keep using it in the updates?
Thanks, Peter :flag133:
you should have no problems with new version of WD
But as time permits I will be adding more to the language.ini file
and so to get the format, backup your exisitng one, then use the create for the first time function, and then copy to the backup the newly created section, or parts that you need, and then reserect the backup to be the in use language.ini file
