Disable Client Viewer File Server
Hello all,
I’ve searched the program and the forum but cannot find the answer on how to disable the startup of the Client Viewer File Server. I would appreciate if someone could point me to the correct location to disable this feature short of renaming the .EXE file.
Thanks in advance.
Randy - KK6RW
see under
setup, control panel, mesomap setup
right down the bottom, allow the clientraw.txt file to be made available to the internet from this pc
(its actualy alows your whole webfiles folder to be available,its a web server)
its use is to allow the clientraw.txt file to be quickly grabbed via http from another wd version, having set that http url in the mesomap station setup
see under setup, control panel, mesomap setup right down the bottom, allow the clientraw.txt file to be made available to the internet from this pc (its actualy alows your whole webfiles folder to be available,its a web server)
Thank you Brian!
One of the places I didn’t look :wink:
Randy
