Dewpoint way off. is it my fault?
In my XML file the record dewpoint for October is -19°C. There is no chance that the dp could have ever been that where I live and I have not had the software running for more than a year anyway.
-19.0
-19.0
What I want to know is where in Weather Display can I modify the month record data. I don’t seem to be able to find a menu for it anywhere!
If someone can help me find it, it would be greatly appreciated!
Cheers
Craig
check the log file, 102004lg.txt
does not have any low temperature readings
(check under view, averages/extreme)
if it does, then edit out the bad record directly in that file
then go action, convert wd log files to graphs, then click on convert
