Description of the clientraw.txt file
Is there a description of the contents of this file? I have searched the forums without any luck. I would like a field by field description
(In fact I only get one page of results returend by the forum search function - subsequent pages return empty!!)
This file is in the wdisplay folder as clientrawdescription.txt file.
example:
12345 6.1 8.5 235 16.3 79 1010.0 0.0 17.6 376.8 0.0 0.0 20.8 0 15.9 0 0.0 0 0 6.6 20.8 22.6 -20.0 -20.0 -20.0 -20.0 0.0 0.0 0.0 21 29 42 Awhitu 0 0 7 4 0 0 7 4 100 100 100 18.5 19.5 15.5 12.5
12345 ID code
6.1 Average windspeed (kts)
8.5 Gust
235 Wind direction
16.3 Temperature (oC)
79 Outdoor humidity (%)
1010.0 Barometer (hpa)
0.0 Daily rainfall (mm)
17.6 Monthly " "
376.8 Yearly " "
0.0 Rain rate (mm/min)
0.0 Max rain rate (mm/min) for the day
20.8 Indoor temperature (oC)
0 Indoor humidity (%)
15.9 Soil temperature (oC)
0 Forecast icon
0.0 WMR968 extra temperature (oC)
0 WMR968 extra humidity (%)
0 WMR968 extra sensor number
6.6 Yesterday rainfall (mm)
20.8 Dallas 1 wire extra temperature sensor (oc)
22.6 " " " 3rd " " "
-20.0 " " " 4th " " "
-20.0 " " " 5th " " "
-20.0 " " " 6th " " "
-20.0 " " " 7th " " "
0.0 " " " extra humidity " (%)
0.0 " " " 3rd humidity " (%)
0.0 " " " 4th humidity " (%)
21 Hour
29 Minute
42 Seconds
Awhitu Stationname
0 Dallas 1 wire lightning count
0 Actual solar reading
7 Day
4 Month
0 WMR968 battery level 1
0 WMR968 battery level 2
7 WMR968 battery level 3
4 WMR968 battery level 4
100 WMR968 battery level 5
100 WMR968 battery level 6
100 WMR968 battery level 7
19.5 Current windchill reading (oC)
18.5 Current humidex value (oC)
15.5 Maximum daily temperature (oC)
12.5 Minimum daily temperatuer (oC)
if you have sync icons set, then
0= imagesunny.visible
1= imageclearnight.visible
2= imagecloudy.visible
3= imagecloudy2.visible
4= imagecloudynight.visible
5= imagedry.visible
6= imagefog.visible
7= imagehaze.visible
8= imageheavyrain.visible
9= imagemainlyfine.visible
10=imagemist.visible
11=imagenightfog.visible
12=imagenightheavyrain.visible
13=imagenightovercast.visible
14=imagenightrain.visible
15=imagenightshowers.visible
16=imagenightsnow.visible
17=imagenightthunder.visible
18=imageovercast.visible
19=imagepartlycloudy.visible
20=imagerain.visible
21=imagerain2.visible
22=imageshowers2.visible
23=imagesleet.visible
24=imagesleetshowers.visible
25=imagesnow.visible
26=imagesnowmelt.visible
27=imagesnowshowers2.visible
28=imagesunny.visible
29=imagethundershowers.visible
30=imagethundershowers2.visible
31=imagethunderstorms.visible
32=imagetornado.visible
33=imagewindy.visible
Current weather description
Baro trend last hour (hPa):for the local file clientraw.txt
the next 20 is the windseed array for the wind speed graph
maximum gust for the day (kts)
dew pointer temperature (oC)
cloud in feet
maximum heat index
minumim heat index
maximum windchill
minimum windchill
Davis VP UV
array of last hour windspeed (10 positions)
array of last hour temperature (10 positions)
max heat index
min heat index
heat index value (oC)
many thanks weatherbee
