Still having similar problems my end with data being mixed up. Have resorted to using 81 seems to be collecting data ok, then manually deleting/renumbering extraneous entries.
Cheers
Steve
Cheers
Steve
re the old dates (which WD does recognise as being too old in the first stage) , I can add more checking too
but I would delete all the data on the data logger, to clear out those old data, so that it does not send them
If I tick the box to clear the datalogger, I’m concerned then that if something went wrong with WD getting and storing the data, that would blow my chances of having a second attempt at extracting it.
Is there some way of using the history extraction program by itself to extract datalogger data into a text file, that I could then import into MySQL?
I do not mean to have that ticked
I mean to clear the data logger of all the data, eg using weather link
as sometimes there can be ghost data left
More of the same results today:
I have cleared the datalogger using Weatherlink this morning.
I have the debug files from all 3 attempts today, but they are pretty similar to yesterdays.
I have set up my IP data logger to 10 minute interval and will do some testing here
I have mine on 1 minute intervals (it is tshattuk that is using 10 minute intervals).
Note, that when the datalogger extraction is run on startup first thing every morning and works correctly, the data goes into MySQL fine. It is just when I go to the setting in Control panel / Datalogger and set a start date and time (and restart WD) to try and retrieve missing data, is the MySQL data capture not so good (ie, I can see records go into the datalogfile, but not into MySQL).
not trying to hijack anything. My problem is much the same. I have made three attempts today to extract data. Mine is set to 1 minute intervals. 81 works fine…
cheers
windi
I have done an overnight test at 10 minute logging interval with an IP data logger
worked great, no problem
Note, that when the datalogger extraction is run on startup first thing every morning and works correctly, the data goes into MySQL fine. It is just when I go to the setting in Control panel / Datalogger and set a start date and time (and restart WD) to try and retrieve missing data, is the MySQL data capture not so good (ie, I can see records go into the datalogfile, but not into MySQL).I do not understand why you would be wanting to to the second part when you say the first part worked fine?
I seem to be missing something
if you could explain in alot of detail what exactly is going wrong?
sorry, not written as well as it could have been…
If all goes well, I don’t need to do anything further. It is only when things DO NOT go well, that I need to use the data logger tool to try and retrieve the data that was not extracted as it should - and it isn’t as successful in retrieving data (and sticking it into MySQL) as I dreamed it might have been.
If so, it seems very strange the latest history data records are sometimes interspersed with old records - and sometimes the same old data records appearing multiple times (as if the Davis has done something wong).
More of the same last night (partial data extraction, followed by a few attempts at manual data logger extraction which resulted in much of the missing data being added to the logfiles (but out of sequence of course), and NONE of the missing data being added to MySQL).
I tried reverting to build R81, but had some com port error, so will just keep plugging away with the latest (although I’m getting reluctant to turn the computer off at night now because my MySQL data is developing huge holes, and missing rainfall)
I have done lots of testing here, at 1 minute interval
but I am not seeing this problem
but it might show up after the data logger is full
what I suggest you do, is when WD is caught up
then power down the console
remove the data logger for 5 minutes (and from the IP plug)
then re insert, power up console, re connect IP plug
then set the correct time and logging interval (with weather link)
so as to completly reset the data logger
OK, done that - we’ll see what happens.
In order to fill the gaps in MySQL, I will use an export from the datalogger from Weatherlink.
well, the next 2 days worked fine, but today was another failure.
Do you know the answers to my previous questions about wind units of measure and incremental rainfall ?
wdisplay debug 160830_1.txt (4.11 KB)
wdisplay debug 160830_2.txt (1.78 KB)
wdisplay debug 160830_3.txt (191 Bytes)
Ok, now that my data logger is full, I am running into this problem
trying to figure out what is going on (its bascily getting out of sync)
Ok, I it sorted in build 21 .zip update, ready now
OK, updated, and (after setting up the datalogger in the Control panel and restarting) it even retrieved the missing data from overnight and got it into MySQL (the datalogfile and graphs in WD are a bit of a mess of course with duplicate and out-of-sequence data, but that doesn’t bother me too much).
thanks Brian, fingers crossed for tomorrow morning
Hi Brian and Steerage 250,
Have run 21 and the data collection is working now. I did put in earlier (one this thread) a debug report and in it it did have something about out of sync…
Anyways looking forward to tomoz to see if all is well, after a second try.
cheers
windi
and mine good this morning too. (Although it does finish the “1st pass” (data extraction?) showing an old time and date (which furrows the eyebrows) - but it seems to work OK)
continuing all good, but my PC won’t get shut-down for the next month (so testing of this fix by me is suspended for a while)
