Datatbase
Brian when the clocks went back last night I was woken up at 1:59am with the computer beeping as the data had base stopped in WD saying something about a key and field “I was still half a sleep so did not rember it all” switched the database off and went back to bed now the data base will not start have you any idea what is wrong.
well, it will be becuase going back for the clock, and the time being a key, it is trying to update records that are already there…
but wait 1 hour then it should be OK
Brian it’s still not working the database will not start and wd is still setup to use the database
