Data Backup causes WD to Crash
I know a few have had this & it only occurs from time to time but tonight WD crashed with a “WD has to close” message.
It is to do with the ZIP backup. My WD is set to backup at 22:00 which means it happens at 22:55.
I checked my Backup folder this afternoon and the 102004.zip files was there along with the registry file both dated yesterday at 22:55.
When I looked at my PC tonight at 23:10 WD has crashed. Before doing anything I looked in the Data Backup Folder, the registry file was there and dated today at 22:55 but the 102004.zip file had gone.
If I do a manual backup it works ok and the 102004.zip file comes back.
My WD had been ok for a week or so.
Hope this info helps to track wn this little bug.
Crashed again last night at 22:55/59. Backup time set to 22.
zip file databackup112004.zip now missing.
V10.18J
I think it is something to do with Windows XP - it doesn’t seem to happen with other operating systems.
I think Brian is scratching his head over this one!
I tried the zip backup for a first time a few months back and although the manual test worked ok - the scheduled one caused a crash which also corrupted data in a datafile for the month.
needless to say I don’t use the databackup function at all.
The strange thing is that it is ok for most of the time and until Aug
yeah, what ever the hour you set, then its at 55 minutes past the hour it does it
i have just turned it on myself…
note, that, you dont need to add files, unless you want to add files that wd does not zip automaticly
i think i should be able to fix this crash with this hopefully
This happen to me when I was running InterWARN at the same time as as WD.
See:
near the end.
i turned this on
set the hour to 7
and it crashed for me :frowning:
i will try and fix this soon!
the latest new version 10.19u looks to have this fixed
(it is for me anyway!)
