Dailyhighlowbaroetc.gif problem
The image above is showing daily high and low soil temps and daily low grass min, with bogus values, even though I do not have any of these sensors.
wd should only be showing the soil temperature on that if you have wd set that you have a soil temperature sensor
check what you have set in the weather station type setup…and untick anything to do with a soil temperature
Nope, nothing appears to e ticked in the station setup…
Tom
humm
emai me your settings files and I will check it out
(go action, back up registry entry now, then email me the files wdisplay.ini and wdisplayftp.reg from the folder databackup)
