Daily Report -
:oops: I used to have it generated, but it appears not to be being generated now. How, where do I get this to be generated? The report I mean is the one which lists the daily extremes and averages and also any daily conditions entered via Input Daily Weather, and then at the month generates, say February2009.htm
thanks
TrevP
Anyone ?
TrevP
make sure you have set to do the daily av/ext under ftp/internet setup, upload times
also, if you go action, update av/ext now
is it updated?
or any error under view, program error log?
Thanks Brian, That’s the setting that I probably needed. Will report back if all is as expected and is waht I was after.
TrevP
I’m having a similar problem with Daily Report
It was working fine during the week(I last looked on 5 March) but the the Daily Reports disappeared.
It still showed the monthly ave/extremes(for March) but only the rain for the previous day.
I tried the suggestions above and now the Daily Report for 8th March(ie yesterday) is there but days 1 - 7 are missing.
(I also did a save and exit and ran the install file again with no difference)
The only different thing I’ve done recently is that I tried to modify the rain log as my rain gauge had gone walkabout,and input new totals under Input Daily Weather.
Any suggestions gratefully received
OS WMR 200 - WD 10.37 build 17
Glad to say that my DailyReport is now being generated…so for some reason I had unset the appropriate field #-o
TrevP
crowded house, try, action, convert WD logfiles to data files, select the logfile, 32009lg.txt, then click on convert
Excellent Brian
Many thanks - back to normal now :smiley:
Still having problems.
Both dailyreport and dailynoaareport neither were created by WD nor uploaded to the server.
I do have the settings on in the Noaa Report box. And when clicking ok it will not update locally nor online.
Regards
Jose
post a screen shot of those settings
also make sure that the main internet switch is on in the connections setup
also, if you go , action, update av/ext now
any errors under view, program event log?
Is on. Other things were transmitted alright.
also, if you go , action, update av/ext now any errors under view, program event log?
No errors.
Regards
Jose
Any ideas?
please, your patience is appreciated
is WD running during the daily reset time? (i.e overnight)
There’s no hurry. I wasn’t sure already if the thread had been lost.
Well, usually WD is running from 6 a.m. to 8 a.m. and 13 p.m. until night (about 11 p.m. up to 2 a.m.)
I’m working on a solution to let it run 24h.
Regards.
Jose
