Daily 24 hours graph
Hi, Brian
Since version 10.17r, WD stopped producing the daily 24 hours graph. I think it’s a bug, as I didn’t change anything, I just downloaded and started that version. Now I have 10.17v and it goes on not producing the file.
Cheers
i am pretty sure i have fixed that…as that was reported…
are you sure its still not being produced in 10.17v?
mine is OK on the web site:
accessible from:
http://www.weather-display.com/windy/gb/October2004.htm
is that what you are refering too?
Yes, Brian, that was what I was referring to… in fact, with 10.17v the same happends, only with the daily 24 hours file, not being produced:
http://meteoabrantes.no-ip.info/October2004.htm
Cheers
i have upgraded mysefl ( i was running the same verison of wd myself for 1 whole week (first time ever), and no problems
so i will see whats up
Thanks, Brian. I’ll see, the next dawn, if there is any change here.
Brian:
Nothing happened, I’m already using 10.17w, but 20041004.gif was not produced.
Cheers
maybe email me your settings
as i ran a test here, and it worked ok (action, update averages/extreme now)
go, action, back up registry entry now, and then email me the file wdisplayftp.reg
note that :
that time stamped file does not actualy appear in the webfiles folder
but on the web site its time stamped (ie. the remote file name becomes time/date stamped)
Hummmm, just before I send you the wdisplayftp.reg…
Now, I’m working with no outside server, or, explaining it clearly, no files are ftped, as I have a folder in my computer where people comes to see my files, through a re-direction service. But everything went fine until last 27 September and the date stamped file was created till then…
ah
that will be it
so, i will have to add option to create it localy as well
i will do that
Thank you, Brian
uploading a new zip 10.17x now with that option added to the web upload times
will be ready to download in an hour or less
Thanks again, Brian
Cheers
a newe zip download is ready now
It’s working fine, Brian. Thanks.
Cheers
