Customtext.. and the units
So, I foud some interesting things about creating a file with data inside to built Excel files afterward…
In my “customtext.txt”, I’ve written things like this “%currentpressureinmb%,%tempinmetric%,%mintemp%…” and so…
here is the question…
When I read the “customtextout.txt” file, I find this "1017.0,17.9
noone can help me ?? :cry:
There’s a global setting - somewhere - to use or not use the “units” with the custom tags. I’m not near my Weather Display computer (it = at home, me = at work) to try and find that setting, but if you can locate it, that’ll solve this problem for you.
In other words, when “send units” is turned on, temperature will read
12
[quote=“n6skk”]There’s a global setting - somewhere - to use or not use the “units” with the custom tags. I’m not near my Weather Display computer (it = at home, me = at work) to try and find that setting, but if you can locate it, that’ll solve this problem for you.
12
Brian’s away for a few days, but I hate to see anyone cry…
So are you saying you have tried all the temp tags and don’t find one that doesn’t include the units? (I guess if it was me I would have all the tags without units and let the user take care of them…) Have you thought of using one of the datafiles like clientraw.txt? Would a third party solution that automatically deletes the units from the data help?
Thanks for not to let me cry… :o
SO, I went to the file you told me, but it doesn’t contains what I need to create tables which I can insert in Excel (to make graphics, archive, etc… that I publish on my website…)
Customtextout.txt is what I need, because I can choose which data I have to keep…
So, for this moment, I try to convert directly the data with units in an Excel sheet… But it’s a bit long way…
When you have a tag like “%currentpressureinmb%”, it’s a good one, without units… but when its something like “%temp%”…
Thanks for the try, I go on with research…
Regards (sorry for english :roll: )
back now
go to setup, control panel, ftp /interneet setup
then custom web page
then untick include units
hi back now go to setup, control panel, ftp /interneet setup then custom web page then untick include units
Thanks for this
I’ll try as soon as possible…
Regards
SO, some news about my problem and its solution…
I try to untick 'include units" in the settings, it seems to work except the wind speed unit… I don’t know why, it’s written like this “22.2 kmh”, with unit…
Another strange thing : I asked WD to make customtextout.txt update every 15 mn.
When I look at the file, I can see each line of record twice… When the station is disconnected (computer shut down), it’s Ok, WD take it from the station when I connect it to the computer…
How can I avoid this ?? :frowning:
which tag are you using for the windspeed?
there are other tags that you could use that will not have the units in it
e.g
%avnodp%
%gustnodp%
i am not sure, at this late hour of the day, exactly what you are trying to say in the second part…sorry…
hi which tag are you using for the windspeed? there are other tags that you could use that will not have the units in it e.g %avnodp%
%gustnodp%
Ok, in the “customtext.txt” I use this for the wind “%avgspd%,%dirlabel%,%gstspd%,%maxgst%…”
And in the “customtextout.txt”, I have this:“17.2,SSW,22.9,22.9 kmh SSW”
So, it’s the “%maxgst%” which gives the unit “kmh”…
For the second part, each update in the “customtextout.txt” file, I have some thing like this: “1010.0,16.9,12.5,16.9,11.8,16.4,72,16.6,SSW,16.0,22.2 kmh N,0.0,0.0,380.4,COUVERT,0.0, 0 %,734,11:00,04/10/2004
1010.0,17.4,12.5,16.9,11.8,16.6,71,17.2,SSW,22.9,22.9 kmh SSW,0.0,0.0,380.4,COUVERT,0.0, 0 %,762,11:00,04/10/2004”, you can see, I have the same record twice, every 15 mn…
ok, i will look into both those things tomorrow
bed time here!
ok, i will look into both those things tomorrow bed time here!
OK, I understand, here it’s only 11:36 AM
Have a good night and no nightmares… :slight_smile:
uploading a new 10.17w now to fix both these issues
Ok, I’ll try this and tell you
Thanks… :lol:
Thanks… :lol:
So, I come back to tell that it works great…!
I’ve not unit yet in the file “customtextout.txt”, and each record is written once and no more twice as before…
So, You did a great work
Thanks a lot :lol:
Just one thing I don’t understand…
On my weather station, I can read 7.8 mm of rain today, and in WD, I read 9.4… something strange somewhere…
