I am trying to modify my webpage and when I change the html file (called kootonline) in C:\wdisplay\webfiles with dream weaver , the next time the internet updates al the changes I have made are gone in the kootonline.html file I have made.
What am I doing wrong?
dont change that file…wd will always update/overwrite that file (determined by your station name in the webfiles/web page setup)
instead make changes to datahtm0.txt or datahtm3.txt or even datahtm2.txt (and then tick, in the webfiles/web page folder, let me mangage the datahtm2.txt file)
Hi thanks for reply , I managed to change the name of the webpage but I still cant make changes to the Text in the table named Weather Data I have set the language.ini file in Dutch as you can see on http://home.quicknet.nl/qn/prive/jh.dekens/kootonline so some of the reading are in Dutch but labels like Current Weather, Maximum Temperature (since 0 hour ) are still in English.
that is all set in concrete
BUT
what you can do is instead use the custom web page option
either turn on the custom web page option in the custom web page setup (ftp/internet setup), and tick to use your station name
and then use the example included with wd (samplecustomwebpage.html)
and change the file name to wxlocal.html
or use the customise internet and file creation …and set times for uploading the wxlocal.html
then you can change things in that file, add more tags, etc
try that
I, ve made a file wxlocal.html in C:\wdisplay\webfiles and every time I update the internet file WD produces a file called wx.html in C:\wdisplay\webfiles . But WD still ftp
are you using the customise internet and file creation setup?
if not, then I recommend to use that
and set times to create and times to upload each file
and then for the wx.html (the remote file name for the custom file), change it to what you need there in that customise internet and file creation screen
Hi that
Can you post your “Dutch” langauge.ini?
TIA,
Cu,
Chow
