Custom screen setup causes kernel error
The new custom screen setup is causing these errors in my trusty Windows ME WD PC (******pause for lots of laughs at me still using ME *****)
I’m also having issues with the list of tags not being ticked correctly for when they are on or off. Some tags are ticked and are off, others are on and not ticked. Using version 10.20o from about 10.00am NZ time today.
Thanks and Merry Xmas.
try 10.20p, as I have done some work on the custom screens, and let me know…
(also, the tick, is that when you right mouse click ?)
also, email me your settings file wdisplay.ini
seems to work OK here the custom screens in testing…
try 10.20p, as I have done some work on the custom screens, and let me know...
Will do.
Yes that is correct - the ticks on the list of custom tags etc.
Will do.
Couldn’t see a ‘p’ version but did download the zip ‘q’ version. This seems ok and did not give me the kernel error on either the slide show or clicking the reset button (as ‘o’ had done).
How do I set a screen back to a ‘blank canvas’.? I had assumed that the reset button did this, but it does not appear to.
How do I set a screen back to a 'blank canvas'.? I had assumed that the reset button did this, but it does not appear to.
Just turn everything off and you will have a blank screen. On/Off is a toggle…
Brian,
If we had preexisting custom screens should the ticking be shown?
