if you are looking for a Marquee you can try this http://discourse.weather-watch.com/p/529124 you can scroll anything you want between the divs.
With the most current version parsing is not ok - ftp is ok.but I thought you said it was working..at one stage..the parsing?
Yes the parsing did work at one stage. But then I could only see it local because the ftp did not work. So I re-installed it later but then parsing did no longer work - but ftp does work again.
I did a fresh re-install. Did you upload a new version in between?
I cant explain what is happening
does not make much sense
I will test here though, tomorrow
I did a fresh re-install on another system (same hardware, same settings) and I can confirm:
the Zambretti weather forecast is working, i.e. the %zambretti% tag in the customclientrawlocal.txt is replaced by a forecast in the customclientraw.txt file.
upload is no longer working, there seems to be a problem with the cronftpreal upload.
Thank you again for your support.
Urs
so what is going on here?
maybe that fresh install , there is a different version of the cronftpreal program?
can you compare?
swap over the programs?
I was unable to make cronftpreal to work.
I made a bash script then using curl.
it might have been a permissions problem
(i.e chaning the permissions of that might have been the solution using chmod)
I will check the permission status of cronftpreal and let you know.
I did install consoleWD on a different system. It seems that the %zambretti% tag is well read in consoleWD version 18.0 but not on the new version 18.3.
Coule you please verify that version 18.3 has the zambretti tag enabled?
Thank you
is this for raspberry pi (and which one) or for linux?
(the more info you can provide the better)
Tank you for your quick reply.
I am using it on a linux PC (x86_64) running Ubuntu 19.10.
try a new update
Ok - it is working now!
Great
Thank you
