Cron-job problem
Hello.
This morning I unfortunately had problems with my cron job.
It will not update the graphs anymore. It stopped last night. I have tried manually, where it works fine, but subsequently stops when it should run normally.
Hope you can help me
Sincerely
Mark
Try using the cron URL in a browser. You may see an error being reported which will give more of a clue about what’s going wrong.
Hi Mark7000
AFAICS the graph data files are correct.
There are minor gaps today between03:36 and 0607:46
https://www.vejret-balslev.dk/pwsWD/PWS_listfile.php?file=chartsmydata/today.txt&type=txt
Can be a problem at the cron server
Or a temporary glitch at your website server.
Or did you solve the problem already?
But for the last hours all data looks OK.
the problem is solved.
It is probably a server error from the Cron Job provider that has been the cause. Everything now works as it should.
Happy Wednesday
