Correcting Month Baro Data
Hi, can anyone tell me which file to edit to correct barometer data. I have rubbish readings for the first 3 days of January, which of itself is not really an issue but the readings are appearing in the Month/Year Records file as extreme/low baro readings and I’d like to correct them without breaking anything. I can’t find anything in the WD software to correct historic baro data. I’m going to assume that the Month/Year extremes are created from a .txt file.
Try 12024lg.txt in log files folder then correct then run convert logfile to graph
Thank you for your reply Harold. Much appreciated
