Convert .inf-file to logfiles does not work correctly
If I do the .inf to logfile conversion I’m getting a wrong sorted logfile:
  1. The logfile starts with the last day AND not complete with the last day of a month (for example here: june 2002):
[list]
day month year hour minute temperature humidity dewpoint barometer windspeed gustspeed direction rainlastmin dailyrain monthlyrain yearlyrain heatindex
30 06 2002 02 01 11.5 71 6.4 1018.2 0 0 0 0.0 0.0 0.0 0.0 11.5
30 06 2002 02 02 11.5 71 6.4 1018.2 0 0 0 0.0 0.0 0.0 0.0 11.5
[/list:u]
Where are the values from 00:00h till 02:00h ?
AND why is the logfile beginning with the last day which is ALSO (and complete) at the end of this logfile?
  1. After the log started with the last day of this month, it continued with a day which is not existing:
[list]
30 06 2002 23 58 11.4 84 8.8 1022.2 0 0 0 0.0 0.0 0.0 0.0 11.4
31 06 2002 00 59 11.4 84 8.8 1022.2 0 0 0 0.0 0.0 0.0 0.0 11.4
31 06 2002 00 00 11.4 84 8.8 1022.2 0 0 0 0.0 0.0 0.0 0.0 11.4
[/list:u]
31.06.2002 ??? This isn’t possible. :slight_smile:
A month-roll-over-(extraction)-problem?
  1. In the short listing direct above you can see, that the day-roll-over doesn’t work correctly by the conversion, too.
    After 23:58h the clock is suddently jumping to 00:59 AND the day is suddently jumping to the next day, too. But this is not correct.
    This behavior is valid for ALL days in the “converted” logfile.
hi all,
miracle here as well 112002lg.txt starts with feature days, clever thing.
31 11 2002 23 56 3.7 95 3.0 1019.0 0 0 90 0.0 0.0 0.0 0.0 3.7
31 11 2002 23 57 3.6 95 2.9 1019.0 0 0 90 0.0 0.0 0.0 0.0 3.6
31 11 2002 23 58 3.6 95 2.9 1019.0 0 0 90 0.0 0.0 0.0 0.0 3.6
01 11 2002 00 59 3.5 95 2.8 1019.0 0 0 90 0.0 0.0 0.0 0.0 3.5
01 11 2002 00 00 3.5 95 2.8 1019.0 0 0 90 0.0 0.0 0.0 0.0 3.5
01 11 2002 00 01 3.5 95 2.8 1019.0 0 0 90 0.0 0.0 0.0 0.0 3.5
probleme now is my av/extr won’t update autom when ftp update start
15 11 2002 12 17 9.2 94 8.3 991.0 0 0 190 0.0 0.0 52.2 538.6 9.2
15 11 2002 12 18 9.2 94 8.3 991.0 0 0 190 0.0 0.0 52.2 538.6 9.2
15 11 2002 12 19 9.2 94 8.3 991.0 0 0 190 0.0 0.0 52.2 538.6 9.2
15 11 2002 12 20 9.2 94 8.3 991.0 0 0 190 0.0 0.0 52.2 538.6 9.2
logfile is complete but no autom transfersion to the file av/extr
manual conversion works
has anyone same probleme ?
DennisHH how’s yours at the moment
one raindy day soon i will fix this, and the rain for the day thing being a day late leo notices…
hi all,
My logfile of november starts at 28 november 2002
28 11 2002 21 33 8.8 74 4.4 1025.0 1 0 292 0.0 0.0 0.0 0.0 8.8
beside it has to be 28 oktober it’s still not the value for the month november of course. it has to do with time settings I know now.
But now it’s almost 28 november it tried manualy to change all lines in av/ex at correct the data to
28 10 2002 21 33 8.8 74 4.4 1025.0 1 0 292 0.0 0.0 0.0 0.0 8.8
but the program resets it all back to 28 november !
So what is the best way, somebody had the same and what to do about ?
delete those initial bad lines in the november log file 112002lg.txt
ok but (there is allways a but)
my av/extr. isn’t updating autol yet (see topics)
so if I convert inf to txt again ( to update till date)
i have those lines back. :?:
you dont need to re- convert to log file
why are you doing that?
because av/extr does not autom update
it stays on the last date I converted it
ok, but recreating the log file is not the way to go
make sure you have ticked upload/update averages/extreme under upload times…
also, you can force a averages/extreme update via action, update averages/extreme now
and you can reset /recreate the averages/extreme file via view, averages/extreme…
make sure you have ticked upload/update averages/extreme under upload times.....[b]yes did before[/b] also, you can force a averages/extreme update via action, update averages/extreme now...[b]yes did before[/b] and you can reset /recreate the averages/extreme file via view, averages/extreme....[b]yes now[/b]
I all had that or did it now
but av/extr. is still on 24th nov now :cry:
any suggestions ? it stopped at about 6 nov
someone else had this same problem
email me your wdisplay.ini file
and export your wdisplayftp.ini file from the registry and email me that
thanks
got the tractor out of the swamp, did some spraying, then ran out of diesel
maybe i should stick to programing, either way i cant win!
just noticed same problem as before in nov
have values from 27/12/2002 till 30/12/2002 (clever ! looks ahead)
av/ex is updating internet but
give me values in the av/extr in the right box only till 2th of dec
then only if converting manual I get it till today
try to reconstruate what I changed before or ticked/unticked
but I can’t find any
make sure you have ticked upload/update averages/extreme under upload times..... [b]OK[/b] also, you can force a averages/extreme update via action, update averages/extreme now [b]OK[/b] and you can reset /recreate the averages/extreme file via view, averages/extreme...[b]OK[/b].
works all but no update til today
are there other tick/unticks i forgot maybe ?
don’t run I can live with it , but I’m just wondering …
Hi to all,
I still have the same problem with the logfile. It starts with 28. date or something like that, does not update automatic and thereis no rain if I convert by hand.
Frank
guys, zip and email em your month112002.inf file
what the problem is , i have discovered , is that at teh begining of the month, that file has the end of last months data in it, so that the grpah history has some data in it to display
so i need to make the log file conversion more inteligant!
and i need to fix the midnigth roll over too (which will be upsetting the averages/extreme update)
if you can zip adn email me that file frank, i will fix :slight_smile:
this should be much much better in a new 9.36e, ready now :slight_smile:
watch here for a storm system headign our way:
http://ps.gen.nz/~windy/moviegms.htm
