I’ll give it a try when I get home this evening. I have 2gb of memory and even after a week or longer I still have between 700 - 1000 free memory.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
well that latest version has not fixed it for me (using a different method of freeing the memory)
as soon as the error shows up in programerrorlog (access violation)
then I cant open setup screens
this is with all my internet functions set on
I am going to go back to having just the minimum set on and turn them slowly on again until the problem shows up
again
Should I still try the zip above when I get home?
Brian, mine lasted 15 hours which is the longest it’s gone.
Tom
@weatherbee
that indicates that I am on the right track, and that the problem is to do with available memory
question: do any of you guys use the custom screen setup? (e.g for signature banner or similar)
I don’t use the custom screen setup.
I’m on my way home now, I’ll check when I get there, not sure without looking.
No custom screens screens here
in my testing, one thing that could be causing a problem is with the auto scale graphs …do you guys happen to have those set to be created and uploaded?
Not me Brian.
the question probably should be:
what do you have set to be created/uploaded?
another question:
do any of you happen to have set to show the real time graphs option (that show to the right of the normal main screen graphs) ?
No real time graphs for me and no auto scale graphs either.
Au
humm, that rules those out then I guess
pwilman, do you use the customise internet and file creation setup?
if so then try turning off things you have set to be created to see if you can pin point the culprit?
what is strange is i have not froze at all since 272 and before that i froze everyday
Brian,
Using customize internet and only using special file conversion #29 I was getting error usually 5-20 minutes. I didn’t have anything else on being created. Turned off #29 and got no errors. Nothing was being created with customize internet. Turned on dirplot.gif only and got error at first creation time.
I think any file created in customize internet can set off the error.
Tom
I am currently having success with the latest .zip update (normal .zip download
http://www.weather-display.com/downloadfiles/weatherdisplaybeta.zip )
(probably spoke too soon now, LOL)
Has anyone tried the latest download? Are people having anymore luck?
Paul
Brian,
I just got a chance to load it now. I’m now running the zip from above, 276. Fingers crossed.
the situation has improved for me
now taking 12 hours for the problem to show up instead of 1.5 hours
so I am on the right track with the changes I have made
will be interesting to see how others go
