oh
thats a big clue
that it carries on running…but no more data arrives from the com port…
now I know more where to look in the code
Hows 10.5b holding up?
This far it runs OK. But I’d like to have some more days on it before I feel safe.
My station: Davis WWIII, consolewd version: 10.5b.
I tired putting 10.5b on, but again after 3 retrievals, get that same error
Mine is still running with no problems.
vers 10.6 is ready, try that stuartturrell
installed 10.6, looked promising, it made it passed 3 data collects, but still errors out.
***Weather Display vers WD_console_10.6****
If use this program,then please consider sending a PayPal donation to [email protected] (Brian Hamilton)
to help with costs, and support, thanks!
www.weather-display.com
Connecting TCP/IP 192.168.1.155 22222
Requesting LOOP data from IP
raw vp baro 994.0
raw vp temp 5.7
Vpsolar = 0
Davis Data OK
Current data : Temperature= 5.7 Windspeed =0.0 Gustspeed =0.0 Direction =308 Humidity=96 Barometer=994.0 Daily Rain=0.6
raw vp baro 994.0
raw vp temp 5.7
Vpsolar = 0
Davis Data OK
raw vp baro 994.0
raw vp temp 5.7
Vpsolar = 0
Davis Data OK
raw vp baro 994.0
raw vp temp 5.7
Vpsolar = 0
Davis Data OK
raw vp baro 994.0
raw vp temp 5.7
Vpsolar = 0
Davis Data OK
An unhandled exception occurred at $000E53B8 :
EInvalidOp : Invalid floating point operation
$000E53B8
$00089D04
$000D5EF4
root@raspberrypi:/home/pi/consolewdfiles#
for neatness, i have disabled realtime and wunderground for now,
does it error on the change in the minute?
if you could .zip and email me your config.txt and your data files
No need Brian, I took this opportunity to buy a new larger, faster SD card so re-install everything from scratch.
Fresh install of 10.6 too and all seems to be running, though it has only been 3/4 minutes, but thats 3/4 minutes longer than before.
Once question, i am using the IP logger at the moment, is there a way from avoiding the endless lines of
“Requesting LOOP data from IP”, or is that unavoidable with weatherlinkIP?
they are just info/debug , that status about the loop
so a fresh install and no data and so no errror?
thats a shame, as I might have been able to duplicate the error here with your data/settings
I still have the other memory card intact.
If you still want them, I’ll get the files off there for you.
Which files are needed other than the config files in Linux?
After 5 days of perfect cruising 10.5 suddenly stopped today. It started again with no problems after a new sudo ./consolewd command. I have sent Brian the datafiles and settings.
@johwin61
what was the error message?
@stuartturrell
see my post above about what is needed
(i.e config.txt and data files)
I might have found something that has been causing problems
in vers 10.7
ready now
Brian,
I’m getting a similar problem…
stage 1 2310 OK
*****Received count = -----------------------------> 1
**** doing minute routines now 13:48:00
An unhandled exception occurred at $000E5E34 :
$000E5E34
$000D94F4
Weather Display vers WD_console_10.7
specifically which files do you want pm’d?
I have been running 10.7 constantly without a single problem since released, not even restarted. Now approaching 2 weeks.
I did some restarts for other reasons. Here WDConsole also going strong. Thanks Brian!!
I ran a test here with my VP with 10.7 and that worked OK for a couple of days after a fix I made for a potential cause of this error
I will run another test with the 2310 station type soon…
Because of the posts above, I have built another pi and reinstalled everything.
So far, so good. Its been running OK for 18 hours…
It just did it again after running for 22 hours…
**** doing minute routines now 20:01:00
An unhandled exception occurred at $000E5E00 :
$000E5E00
$000D94F4
