Consolewd and rain rate
I am using a weather station from HomeMatic, have from the data generate the datain38. file, then use consolewed to produce the customclientraw.txt and other files. These then are used for display with the SteelSeries Gauges.
Now my question is how can I feed the gauges with rain rate. Does datain38.ini/wdconsole allow for this
You might have to ask Brian direct, at [email protected]
Iā€™m not sure why you want to display rain rate, as it seems to mean different things to different people:
Can you give us the URL for your SS Gauges?
This is the URL for my SS gauges:
http://80.219.133.218/liveweather_bern.htm
I just realized that it works now, maybe it just needed for consolewd some time to calculate the rain rate.
